HELP, what speakers for this setup.
Username: Simonoaks
Hi,
I have for the first time in my life decided to buy a (what I hope to be) resonable good HiFI system. read up about it on net (this site has been good), and just visited Richer Sounds. I am thinking of going for CA 640A and 640 C with Marantz TT42, M/s 914 speakers (£249.95), and ULTRA100 cable (£4.99 per metre) and Studro cable (£39.95). Can anyone tell me if this setup is good, and if I am using the correct speakers, cables etc for this kit. Very new to this so would appreciate advice.
many thanks
Simon
Username: Petergalbraith
Rimouski, Quebec Canada
Post Number: 205
Don't overspend on speaker cable. Plain 14 or 12 AWG is fine.
Username: Frank_abela
Berkshire UK
Post Number: 124
More rubbish about cable not making a difference. Richer will have advised you to the best of their ability and they understand their systems well. Go with the recommendation if possible. If you've heard the system, then check what cabling they used and try to get that.
Cables make a massive difference to systems - ignore them at your peril.
regards,
Frank.
Post Number: 214
Where's the link to the guy from Marantz when you need it...
Post Number: 215
Wasn't from Marantz after all; from McIntosh...
http://www.roger-russell.com/wire/wire.htm
