Speakers with HK
Username: Sjordan872
Hi guys. I've recently purchased an HK 630 and would like to now direct my attention to adding speakers (5.1 for now). I live in a condo so I'm thinking bookshelves for the mains would be the way to go. I'm considering Klipsch, Infinity, and maybe JBL. Yes, I know who Harman owns. Does anyone have an opinion on which of these would blend best with the warm soundning HK? Or are there any others you might recommend? I'd like to keep it in the same price range as the 3 I mentioned. Thanks in advance for your thoughts!
Username: Hteaterjunkie
Post Number: 17
Blazer,
I have personally heard the Klipsch and HK combo and think they match beautifully. I would not hesitate for a second recommending that combo to anyone
Hope this helps.
Username: Hawk
Post Number: 87
Blazer:
The HK has a very laid back, relaxed sound to it, so the best speaker match is a speaker that is very detailed to bring out the resolution that the HKs have, but can get lost with the wrong speaker. Klipsch is a very good choice, but Ininity and JBL are not.
Other speakers you should consider are JMlabs, Monitor Audio, Canton, M & K, and Athena.
Congrats on the new receiver and Good luck!
