DAC output muting relay causing nasty click
Anynamewilldo
Hi. The output relay on my DPA 'Little Bit' is causing a really nasty 'click' over the speakers when a CD is found by my player. Anybody know if the relay itself is to blame, or is some other component failing? Cheers, David Stenhouse
Need to Register?
Forgot Password?
Enable HTML code in message
