New member Username: KwngagePost Number: 1 Registered: Oct-04 | A home theater dealer has proposed Tannoy Eyris DC3 speakers, but I can't find much about them on the Internet. He doesn't have the DC3's for me to listen to, but he says that he will exchange them if I don't like them. He also carries Monitor Audio products and I'm thinking the Gold Ref 20's may be a safer route. Does anyone have any experience with the Eyris DC3's? I would use the DCC center and EFX-1 surrounds, Earthquake MKV-15 sub, B&K Ref 50, B&K Ref 200.7. Thanks! |
Silver Member Username: LandrovalPost Number: 843 Registered: Feb-04 | I have experience with the Eyris DC1 and Sensys DC1 which were quite good actually. They dont seem magnificent at first, but the longer you listen to them you'll find them very pleasing. The 3D imaging is much better than with most normal speakers, and the uniformity between the speakers is very good. I usually find coaxial designs superior to separate drivers, it's so much better when the sound comes from just one point. Here's a review of the Eyris non-DC: http://www.homecinemachoice.com/reviews/wvreviews/SpeakerPackages/Tannoy/TannoyE yris.php Sensys non-DC: http://www.homecinemachoice.com/cgi-bin/displayreview.php?reviewid=2972 Sensys DC: http://www.homecinemachoice.com/cgi-bin/displayreview.php?reviewid=3392 |
Silver Member Username: Rh1Post Number: 293 Registered: Jun-04 | Kent....What Hi-Fi Magazine has a review on these for the nOvember issue |
