Athena AS F2/HK 7200
Username: Loriglenn
Are the Athena AS F2's a good match for the HK 7200?
Username: Project6
Post Number: 97
I think they sound well together
cheers
Username: Edison
Post Number: 289
I like the sound of Athena AS-B1 ($150 at www.bestbuy.com) with a sony sub sa-wm500 ($129 on ebay) better. The smaller woofer (5 inch) has a pretty sound - the big ones are not as focused.
You might want to hear them with a sony sub - sounds mesmerizing.
Also consider NAD or onkyo receivers - they both were received better than HK on www.hifichoice.co.uk
http://www.hometheaterhifi.com/volume_10_2/onkyo-tx-sr800-receiver-4-2003.html
www.ecost.com has a goos price on it.
