Marantz or Marantz
nikofdus
Should I go in for a SR5400 OSE or SR7300? Both are available at the same price point. I think the 7300 has better bass management and also multi-room feature which the 5400OSE does not.But then the OSE is supposed to have special components?!! Can anyone compare the 2 receivers for me? The offer is valid for a couple of days only....Thanks a ton
Nik
Username: Landroval
Post Number: 705
Ok. Read this:
http://www.hifissimo.com/store/loadpage.cgi?user_id=1230&file=text/be_marantzsr5 400ose.html
Use Babelfish to translate if you cant read the dialect of Paris.
Basically he says the SR7300 has no chance against the 5400OSE.
nikofdus
Thanks Landroval. I did read the translated text. It seems the SR7300 is no match. That makes the decision making far simpler than I thought. DO you have any idea of the bass management of 5400OSE? Is it fixed at 100 Hz?
Username: Landroval
Post Number: 708
As far as I remember it's 80, 100, 120Hz or something like that.
nikofdus
Thanks again. If it is at 80Hz it's good enough for me.
