Bronze Member Username: Pbplayer05Carroll, Iowa Post Number: 68 Registered: May-07 | well i have a 1/0 gauge wire and i was wandering what kind of fuse holder i should get or possibly a cercuit braker and where to get them? what would u recommend |
Silver Member Username: Yamahabanshee1Paulding, Ohio USA Post Number: 408 Registered: Jul-04 | i run the agu fuse holder with a 300amp fuse from audiopipe and its great! i dont like the circut breakers! they trip easy but i guess u can just flip the switch but it needs reset often |
Gold Member Username: BernymacCambodian Post Number: 2984 Registered: Sep-04 | get an anl fuse holder. |
Gold Member Username: Tremor1127Team Fi Car Audio [:-] Post Number: 1781 Registered: Aug-06 | yeah, get an anl fuse holder. they can be pricey, they run anywhere from $15-$100 here... i buy the $15 ones... ![]() |
Silver Member Username: ImalikSD2.5......ED9.1=Boom, New Jersey Audioque...N... Post Number: 405 Registered: May-06 | ANL fuse and holder for sure..Check your amps manual on what size fuses to use. The holder is $7.50 1/0 gauge from ROE store. thats where I got my holder from http://store.realmofexcursion.com/ |
