WiFi Site Survey by WiTuners (Android) Review
With the ability to load floor maps, view heatmaps and import and...
(4 out of 5)
Anyone responsible for deploying and managing wireless networks will undoubtedly have some familiarity with the various wireless networking tools and site-survey programs that exist. Some of these programs help monitor a wireless network, and others help you to conduct a survey on-site of a planned wireless network to optimize Wi-Fi coverage.
Such tools and software typically run into the thousands of dollars and often require lugging around laptop to each customer’s site. Wolf WiFi Pro is an app for Android devices, one that provides a surprising number of features offered by more expensive networking utilities, all for a bargain price of $50.
Wireless Networking with Wolf WiFi
Available on Google Play, Wolf WiFi Pro requires Android 2.2 and up. It’s also available on the Cisco AppHQ Market. The developer, Wolf WiFi, claims its app is “enterprise class,” and it does provide a lot of great functionality. You can use Wolf WiFi to search for Wi-Fi networks, monitor 802.11 channels, import floor plans, create heat maps, and more.
Upon opening the app, you see six options displayed on the home screen: “WiFi On” (enables or disables the Android device’s Wi-Fi’s, “Wake Lock off” (controls the device’s sleep and dim settings), “WiFi Scan,” “Channel Scan,” “Site Survey,” and “WiFi Manager.”
WiFi Scan lists all wireless networks in the area. You can get details on information such as SSID, BSSID (the MAC address of the access point), the radio signal level (in decibels) and whether the network is secured or not. The app also identifies which access point the Android device is connected to.
A tap on a listed network brings up two options. You can manage the Wi-Fi connection, which pulls up the default wireless network setting interface in the Android OS. You can also opt to “Track Signal Source.” This cool feature tracks down the physical location of an access point. A steady tone is emitted from the Android device. The tone gets louder as you move closer to the physical access point the device is connected to. It reminds me of the way fox and hound tone generators work for locating network cables.
Of course, using this feature to locate an access point in an enterprise that may have hundreds of access points deployed (across a campus for example) is not very practical. But in a smaller environment it’s a handy tool. Tracking signal source is particularly helpful in positioning an access point’s antenna for optimal placement.
The channel scanning feature graphs both bands of the network channel information. This feature is a good way to resolve issues of interference and channel overlap. You can drill down on channels and see how many access points are on them. Since it’s hard to get a good look at the graph on a smartphone ‘s small screen, the app is best installed on a tablet if this is a feature you would use a lot .
Of course, many of these capabilities like channel scanning and identifying wireless networks in proximity can be done with other comparably-priced solutions like NetSurveyor. However, one capability that distinguishes Wolf WiFi from other relatively low-cost wireless networking tools is it can be used to perform and map out a professional-grade site survey.
Site Survey
What I like most about the site survey capability is you can easily upload a site’s floor plan into the app as a .BMP or .JPG image. Once uploaded, Wolf WiFi has several built-in icons for you to customize the floor plan. There are icons for routers, access points, antennas, bridges and more.
Once your floor plan is populated with icons, you can walk about the site and record signal strength. Recording is as easy as adding icons to the floor plan, both are done with a double-tap. The app has an “Undo” button in case you want to delete an icon or stop recording. The device performs an active site survey, meaning the device has to be connected to the site’s wireless network.
After you are finished taking signal strength samples, a color overlay is displayed over the floor plan. This overlay is color coded to indicate the wireless signal strength in the area you recorded.
There are several ways to view information about your site. You can filter the floor plans to display only access points, or by secured APs, and more. You can display a heat map of the area, however you do need to collect several samples before the app has enough information to build the heat map.
Wolf WiFi’s Got Bite
Although Wolf WiFi is marketed as enterprise-class, it’s not a heavy-duty site survey tool like one you would find from Fluke Networks. For instance, there is currently no way to test how changing specific factors, such as an AP’s channel, will impact a customer’s wireless network.
However, Wolf WiFi’s developer states such capability is on the company’s roadmap (the trick is building that functionality without rooting the Android device). Tools like PING, Telnet and SSH, HTTP management tools— so you can connect to your devices right from the survey— will be added as well as device management and other features in a future update.
There are other Android apps that will provide wireless network monitoring; yet most of them are limited to performing scans to find out nearby access points and to analyze channel usage. Wolf WiFi Pro is unique in that it gives you the site survey abilities of weightier tools traditionally run on PCs, albeit, not the full capabilities of more expensive tools.
You still can’t dispute the handiness of Wolf WiFi Pro for smaller Wi-Fi site surveys and network monitoring. It’s relatively easy to use and comes at a great price. It will be interesting to see just how much functionality the developer will be able to cram into this app. It’s an app that’s already excellent, easily earning 4 starts and Editors’ Choice for networking utilities.
More Networking Software Reviews:
By Samara Lynn, PCMag
