Daily Deals
SVS Ultra Series Closeout Sale!
SVS is having a closeout sale on its Ultra series loudspeakers to make room for the just announced Ultra Evolution series. Save up to $600 while supplies last.
SVS Ultra Series Tower and Center Loudspeakers in Gloss Black Lifestyle
SVS is best known for its award-winning subwoofers, but it would be a huge mistake to not consider its wide range of loudspeakers as well. If you are looking to build a high-end 2.1 or 7.2.2 home theater system — their products deserve some serious consideration.
With the impending release of its Ultra Evolution Series loudspeakers, SVS has decided to clear out its current Ultra Series speakers to make room. This means that if you are looking to purchase some great speakers, this may be your best opportunity to save a lot of money on these award-winning speakers.
SVS Ultra Series Loudspeakers in Gloss Black
SVS Ultra Series
SVS Ultra Sale
First introduced in 2012, the SVS Ultra Series have been its flagship loudspeaker series for more than a decade.
Music listeners can save up to $600 on a pair of the Ultra Tower loudspeakers and there are other savings to be found on the rest of the lineup.
This is a final sale and once the inventory is sold off — you are out of luck.
Here are the speakers included in the closeout sale:
  • Ultra Tower – Save $600/pair
  • Ultra Bookshelf – Save $400/pair
  • Ultra Center – Save $100
  • Ultra Surround – Save $400/pair
As an added incentive, a 5% savings is also available when purchasing 5 or more products with promo code “System”. This includes subwoofers, Prime Series speakers, and items from the Outlet Store. All SVS speakers are timbre-matched which means they can be mixed-and-matched and will blend seamlessly in a home theater.
The SVS Ultra Series Speakers incorporate design characteristics to deliver reference sound quality. Rendering a broad soundstage with incredible resolution, pristine clarity, and amazingly rich and articulated bass, SVS says its Ultra Series speakers can stand toe-to-toe with more expensive high-end hi-fi and home theater speakers.
SVS Ultra Bookshelf, Surround and Center Speakers in Gloss Black
SVS Ultra Bookshelf, SVS Ultra Surround, SVS Ultra Center
SVS Ultra Comparison
Ultra TowerUltra BookshelfUltra CenterUltra Surround
MSRP/each
Sale/each
$1,299.99
$999.99
$599.99
$399.99
$799.99
$699.99
$599.99
$399.99
Speaker Type3.5-way 2-way3-way2-way
Tweeter1-inch Aluminum Dome1-inch Aluminum Dome1-inch Aluminum Dome2 x 1-inch Aluminum Dome
Midrange2 x 6.5-inch Composite glass fiber cone1 x 4-inch composite glass fiber cone
WooferDual 8-inch Aluminum1 x 6.5-inch Composite glass fiber cone2 x 6.5-inch Composite glass fiber cone2 x 5.5-inch Composite glass fiber cone
Port (Bass Reflex)3.5-inch wide-flared rear-firing port1 x 1.7-inch wide-flared rear-firing port2 x 1.7-inch wide-flared rear-firing port
Crossover Points160Hz, 700Hz, 2kHz2kHz500Hz, 2.2kHz2.0kHz
Frequency Response (+/-3 dB)28 Hz-32 kHz 45 Hz-32 kHz45 Hz-32 kHz58 Hz-32 kHz
Recommended Amp Power20-300 watts20-150 watts20-225 watts20-250 watts
Impedance8 ohms8 ohms8 ohms8 ohms
Sensitivity (2.83V @ 1 meter)88 dB87 dB87 dB87 dB
Dimensions (HWD with Grill)45.6 x 13.8 x 16.8-inches 15 x 8.5 x 10.9-inches8.2  x 22 x 10.9” inches14 x 12.3 x 7-inches (with bracket)
Weight75.4 lbs19 lbs31 lbs18 lbs
Price & Availability
The SVS Ultra Series speakers are available directly through SVS or Amazon. All models are available in Gloss Black, Gloss White, and Black Oak Veneer finishes while supplies last.
Tip: The SVS Ultra Evolution Series should become available during the first quarter of 2024, although we’re still awaiting an exact release date.
In bookshelf, center channel or floorstanding sizes, the ELAC Solano 2.0 series loudspeakers bring their JET 6 Tweeter to your home theater.
At $1,999/pair, the ELAC Elegant BS 312.2 Bookshelf Speakers are more deep than they are tall and come with colorful grille options.
At $115,000/pair, the Estelon X Diamond Signature Edition Loudspeakers will be limited to just 20 pairs.
Do the Acoustic Energy AE100 MK2 Loudspeakers compare favorably with the competition below $500? They should be on your audition list for sure.
Build a complete audiophile-grade stereo system around the Acoustic Energy AE1 Active Bookshelf Loudspeakers for under $4,000.
In celebration of the beginning of its 50th Anniversary, ATC is proud to announce the forthcoming release of an exclusive new active stand mount...
Andrew Jones third loudspeaker and first floor stander with MoFi Electronics arrives Q2 2024 for $5K/pair.
At $1,299/pair, the Totem Acoustic LOON is the company's most affordable bookshelf speaker yet.
