Sony Alpha NEX-F3 Digital Camera Review
By
Updated: July 18, 2012
This entry-level interchangeable lens camera sports a great feature set, snappy performance, and excellent photo quality. And, unfortunately, a pretty lousy user interface.
4 stars
(4 out of 5)
If you’re looking for a low-priced interchangeable lens camera, then the Sony Alpha NEX-F3 should certainly be on your list. It has great photo quality, a complete set of features, and snappy performance. The only thing I’d recommend is trying one out in person before you buy, as the user interface leaves much to be desired. If it doesn’t bother you, then you’ll definitely get your $600 worth if you pick up the NEX-F3.
Read full review @ Digital Camera Resource Page
Pros
  • Very good photo quality — low noise through ISO 1600 in low light, ISO 12800 in good light
  • Good value for the money
  • Sharp 3-inch LCD display can flip upward 180 degrees, allowing for easy self-portraits
  • Snappy performance in most respects
  • Full manual controls, including RAW support — focus peaking feature comes in very handy when manually focusing
  • Intelligent and Superior Auto modes make point-and-shoot photography a snap
  • D-Range Optimizer and HDR features improve contrast at the push of the button
  • Fun sweep panorama feature
  • Very fast burst mode shoots at 3.3 fps with continuous AF or 10 fps without it (but not for long)
  • Helpful Shooting Tips and descriptions of each menu option
  • Records Full HD video at 60i or 24p, with stereo sound, continuous AF, image stabilization (if available), and manual controls
  • Optional super high resolution electronic viewfinder, stereo mic, external flash
  • Above average battery life
Cons
  • Consistently underexposes by 1/3 or 2/3 stop
  • Menu-driven user interface still frustrating to use, even with addition of custom button
  • Design annoyances: camera’s size advantage lost when a lens is attached
  • LCD’s 16:9 aspect ratio not suited for still shooting
  • LCD doesn’t tilt downward very much
  • Buffer fills quickly in burst mode
  • Bare bones playback mode — can’t view stills and movies at the same time
  • Internal battery charging is slow, can’t be used for a spare
  • Full manual on CD-ROM — quality of manuals is not great
