Sapphire Radeon HD 7790 2GB Review
We’re straying into the faintly awkward territory of frame buffer capacity here....
This far down the pecking order of graphics cards you will really struggle to get anything close to decent gaming frame rates out of a normal 1080p screen.
With the Sapphire HD 7750 you’re not going to be pushing much past 20 frames per second in most games without seriously knocking back the graphics settings or resolution.
This version of the HD 7750, with the 2GB of relatively slow DDR3 video RAM, is almost irrelevant in gaming terms. That said, though, you can pick up a low-profile version which could go into a small machine to stick under your TV.
With Steam’s TV mode, and a drop in resolution, you’ll be able to get almost gaming-capable speeds at 720p on your telly. For another £20, though, you can get double the gaming performance with an HD 7770, and £50 extra will get you the awesome HD 7850 1GB.
If you’re finding your budget stretched for a new graphics card you would be better off saving up for a little longer and paying a little more. The rewards for just that £20 investment are pretty big in gaming terms.
At this low level the Nvidia competition is the GT 640, a graphics card that’s not even permitted the GTX moniker. There is pretty much nothing between AMD and Nvidia at this range, so it would just be a case of choosing whether you might want a low-profile HD 7750 instead of the standard height Nvidia cards on offer.
It is possible to get gaming frame rates at this price point, but the sacrifices to graphical fidelity might mean it’s not really worth it.
By Dave James, TechRadar
