HP Pavilion TouchSmart Sleekbook 15 Review
Mainstream laptops are really starting to impress these days – not only...
(2.5 out of 5)
The Samsung Series 5 NP535U3C-A01US looks like an ultrabook, feels like an ultrabook, and will be sold alongside ultrabooks, but don’t be fooled. Although there are plenty of superficial similarities, the Series 5 NP535U3C is built around an AMD processor, a change that affects not only price but also overall performance in ways most consumers are not likely to benefit from or appreciate.
When Intel launched its proprietary Ultrabook specification, most OEMs got right on board, as evidenced by the current glut of super-thin laptops on the market. But for a laptop to get the Intel-approved Ultrabook brand name, it must meet certain requirements for thickness and weight and use Intel’s hardware. In response, AMD has begun partnering with manufacturers to make laptops that look and feel like ultrabooks, but will be marketed under various descriptions and labels; HP is using the term Sleekbook, for example, and Samsung says its notebooks have a “sleek and chic design.”
The bottom line regarding these machines? They are the same in many respects as their ultrabook counterparts, often using the same chassis and components, but they diverge on one key point: Their use of AMD processors naturally results in slightly different performance. They also hit lower price points than the Intel-based systems, and AMD is hoping that costing a couple of hundred dollars less will close any gaps in shoppers’ minds.
On the outside, the Series 5 NP535U3C is identical to the Samsung Series 5 Ultra NP530U3B-A02 , a middle-of-the-road ultrabook. It weds an aluminum lid and palm rest with a fiberglass underside for a look that complements the sleek footprint (0.69 by 12.4 by 8.6 inches, HWD) and light 3.35-pound weight (just a tad heavier than the Series 5 Ultra, which weighs 3.1 pounds).
A chiclet-style keyboard has black matte-finished keys, but not the backlight you’ll find on the HP Folio 13-1029wm . The touchpad, in a welcome departure from the blank clickpads seen on other laptops like the Lenovo IdeaPad U310 , has a basic multitouch surface and separate right and left mouse buttons, thereby reducing inaccuracies, accidental clicking, and the need to retrain yourself to mouse with one finger.
The Series 5 NP535U3C has a 13.3-inch matte screen, meaning that even in a brightly lit room or outdoors you can still take advantage of the 1,366-by-768-resolution display. It doesn’t match the 1,920-by-1,080 resolution on the Asus Zenbook Prime UX32VD-DB71 , but for browsing the Web or watching shows on Netflix, it’s just fine—not to mention coming in at half the price. The audio, on the other hand, is only so-so. When tested with some Bill Evans and Art Blakey, the volume was good, but the sound clarity dropped off at higher volumes, and the bass was nearly nonexistent.
Compared with other ultrabooks, the port selection on the Series 5 NP535U3C is perfectly adequate, comprising two USB 2.0 ports, one USB 3.0 port, a compact Gigabit Ethernet port, full-size HDMI out, and a mini VGA port (which requires a separately sold dongle to use). A card reader supports several formats (SD/SDHC/SDXC/MMC), but it’s awkwardly designed. Like many manufacturers, Samsung fills the empty slot with a plastic placeholder to keep out dirt and foreign objects. But unlike competitors, Samsung doesn’t use a spring-loaded design to pop out the placeholder or memory card with a gentle push on the end; instead, the lack of an ejection system means you have to pry it out with a fingernail or small tool. Once removed from its slot, the plastic placeholder is equally challenging to replace properly.
Internally, the Series 5 NP535U3C is equipped with 802.11n Wi-Fi and Bluetooth for wirelessly connecting headsets, keyboards, and mice. But you won’t find two features common on ultrabooks: an optical drive or Intel’s proprietary Wireless Display (WiDi) technology for streaming HD video and audio content over the air. The Series 5 NP535U3C is also equipped with a 5,400rpm 500GB hard drive. This matches the drive sizes seen in the Lenovo IdeaPad U310 and Dell Inspiron 14z (Summer 2012) , but it doesn’t include the 32GB cache of flash memory that makes ultrabooks so nimble.
On the hard drive, you’ll find several preinstalled programs, including a 30-day trial of Norton Internet Security, Microsoft Office Starter 2010 (with limited Word and Excel capability), and several free programs like Amazon Kindle Reader, Skype, and Xerox PhotoCafe. A Bing Bar gloms onto Internet Explorer, and a handful of samples from WildTangent Games provides a bit of free play. Samsung covers the Series 5 NP535U3C with a one-year warranty.
Where the Samsung Series 5 NP535U3C really diverges from Intel-approved ultrabooks, however, is in its processing hardware. It is outfitted with a dual-core 2.1GHz AMD A6-4455M Acclerated Processing Unit (APU), and is paired with 4GB of RAM—which, as mentioned earlier, results in significant performance differences. Case in point: The Samsung Series 5 NP535U3C scored 1,337 in Futuremark PCMark 7 and 0.87 in CineBench R11.5. By comparison, the Intel-powered Samsung Series 5 Ultra NP530U3B-A02 scored 3,330 on PCMark 7 and 1.74 on CineBench with nearly identical hardware save for a second-generation Intel Core i5 processor. The Lenovo IdeaPad U310, which costs about the same but boasts a newer third-generation “Ivy Bridge” Intel processor, performed even better: 3,570 in PCMark 7 and 2.39 in CineBench. The AMD-powered Series 5 NP535U3C also fell far behind in multimedia tests, completing Handbrake in 4 minutes 5 seconds, and Photoshop CS5 at a snail-like 7:27.
Sharing the same chip die as the AMD A6 processor is an AMD Radeon HD 7500G graphics processor. Though it supports DX11, it was unable to run our Crysis and Lost Planet 2 gaming tests, and offered weak scores in 3DMark06, where it earned 4,216 with medium details and 1,024-by-768 resolution. This is a step up from the 3,469 scored by the HP Folio 13-1029wm or the 3,234 scored by the Intel-powered Series 5 Ultra, but these systems used the older second-generation processors. Compare this with the score of the Lenovo U310 (4,978), which uses Intel’s third-generation integrated graphics processing but achieved markedly better results.
The final area of performance we test is battery life, using MobileMark 2007. With its 45Wh battery, the Series 5 NP535U3C lasted 5 hours 23 minutes, falling behind the Toshiba Portege Z835-P330 (7:35) and HP Folio 13-1029wm (8:40).
As an inexpensive ultraportable, ultra-low-voltage laptop, the Samsung Series 5 NP535U3C-A01US is passable, but only if you ignore the similarly priced competitors sitting next to it in the laptop aisle. Value shoppers will do better to choose the HP Folio 13-1029wm, and the Lenovo IdeaPad U310 or the Samsung Series 5 Ultra are two Intel-powered ultrabooks with comparable features and prices but better processing capabilities. As for the AMD-powered Series 5 NP535U3C-A01US notebook, we recommend you pass it over.
BENCHMARK TEST RESULTS:
Check out the test scores for the Samsung Series 5 NP535U3C-A01US
Compare the Samsung Series 5 NP535U3C-A01US with several other laptops side by side.
By Brian Westover, PCMag
