Phiaton PS 210 BTNC In-ear Headphones Review
By
Updated: November 23, 2012
Performance:
3.5 stars (3.5 out of 5)
Value:
4 stars (4 out of 5)
Sonically, the Phiaton PS 210 BTNC stands up to many headphones of the same price that don’t have noise cancelling and Bluetooth 3.0. The half in-ear design is very unique and should help keep the headphones in place for most people. The noise cancelling works nearly as well as the others I’ve tested and the wireless connection doesn’t depreciate audio quality significantly. With the ability to bypass the wireless if the battery dies, the Phiaton PS 210 BTNC are easily the most flexible earphones I’ve tested. With very good audio quality, a full suite of features, and a unique design, the Phiaton PS 210 BTNC headphones definitely get my recommendation.
Read full review @ Audioholics
Pros
  • Overall excellent Bluetooth and wired sonic performance
  • Able to use even when battery is dead
  • Central control unit means either headphone can be used for calls
  • Long battery life
Cons
  • Unique design means might not fit all ears
  • Bluetooth connection inconsistent
  • Control unit clip weak
  • Only USB charging out of box
