Finlux 55S9100-T Review
A 55-inch 3D TV currently reduced to £999.99 – say what?...
We had expected the latest iteration of Panasonic’s king of plasmas to be a numbered upgrade of 2012′s awesome VT50 Series, but although a VT60 has dutifully appeared at the CES, it’s thunder has been politely removed by an all-new plasma that Panasonic is calling ‘Beyond Reference’.
That’s impossible, of course – a reference is by definition the ultimate, and can’t be bettered – but Panasonic’s engineers have certainly given 110% on the newborn ZT60 Series.
Including the 60-inch 60ZT60 as well as this 65-incher, the ZT60 uses an all-new Studio Master panel alongside all of Panasonic’s latest smart stuff such as voice interaction, Swipe and Share, and Viera Connect apps.
As befits a new monarch of movies, the 65ZT60 is a stunner on the outside, too. We’ve rarely been crazy about the outward appearance of a Panasonic TV, but the 65ZT60 breaks the mould with a slim bezel to rival – well, probably last years – LED TVs. The 65ZT60′s plasma panel is actually bonded to the front of the glass itself, principally to remove reflections, though it would appear to have helped boost brightness, too.
A lack of brightness has historically been a problem for high-end plasmas, and a significant drawback when watched in bright daylight, but it’s not an issue here. That’s thanks in part to a new pre-discharge control method, and though details were scant, we witnessed some intensely bright white segments if an image on a totally black blackground.
You know something’s up when a TV is given its own black-curtained room, and it’s to such a place that we were ushered to put the 65ZT60 through its early paces.
NeoPlasma Black 3000 is the slightly wordy term for a couple of dramatic differences in the tech that has wound-up in the 65ZT60. The first is red – and lots of it.
Using a new red phosphor has enabled a wider colour palette that technically surpasses the parameters of the digital cinema DCI standard. It shows up most dramatically in the appearance of red, which is more nuanced, but also much more powerful, though overall this increased skill with colour lends relatively more depth than in previous models.
The Studio Master panel also appears to be much sharper. This is surely down to perhaps the 65ZT60′s biggest advancement, Ultra Fast 3000 Focused Field Drive, which shortens the light emission to 1/3,000th of a second to eliminate after-images and blur.
It works well, though the increased sharpness appeared to introduce some processing artefacts. A moving shot of fine hair did include some fizzing around the edges, though it only seems to occur during close-ups.
“LED TVs can outsell plasmas as much as they want – there’s no way we’re giving up on the best picture tech”, said a Panasonic booth attendant to a small audience of speechless AV enthusiasts. He has a good point, because when watched in a blackout the 65ZT60 simply pops eyes.
The step-down VT60 Series of plasmas doesn’t offer a bonded panel, but oddly does add a pop-up webcam for instant Skype.
By Jamie Carter, TechRadar
