Mitsubishi HC8000D and HC7800DW DLP Projectors
Mitsubishi has introduced the HC8000D and HC7900DW home theater projectors, which use...
(3 out of 4)
The Greatest Show on Earth
The Mitsubishi WD-92840 is without a doubt, one of the most fascinating home theater products I’ve experienced. In some respects, it is impractical and unforgiving in the wrong environment. It spits in the eye of the rest of the industry at a time when everyone is fighting to see who can make an HDTV as thin as a sheet of paper. It needs its own room with controlled lighting for optimum set-up. With all of that stacked against it, one still can’t help but admire the overall experience; that feeling that you are finally viewing a “big-screen” HDTV that looks pretty spectacular with 2D if you take time to squeeze every last drop out of it. If I had $10,000 to spend on a large screen video display, I would still buy a front projector/screen combo without hesitation. If I had around $5,000 to spend and only had room for a flat-panel HDTV, the Panasonic 65″ VT50 would probably be my choice. But if I had under $5,000, wanted that big screen experience and had the room and control over ambient light, the WD-92840 would be the easiest buying decision I ever made. Highly recommended.
Read full review @ Big Picture Big Sound
