Fanny Wang 3000 Series Review
By
Updated: July 13, 2012
fanny-wang-3000
Performance:
4 stars (4 out of 5)
Value:
If you are a frequent traveler, noise canceling headphones are either a thing you own or a thing you covet. Fanny Wang Headphone Co. has recently come on the scene with high end headphones that are targeted at the discerning consumer. The Fanny Wang Series 3000 headphones are a very nice sounding set of cans that feature not only a Pass Through mode for use when the batteries die but also Noise Canceling and Noise Canceling with Bass Boost. Part of that $300 you are spending on them went into the noise canceling but not all of it. While it didn’t hold up to dedicated headphones in the same price bracket, it did well against some highly regarded, but cheaper, sets. When you add in that you’d likely be using them in noisy environments, that they are comfortable enough to wear all day, and that they included everything you’ll need to enjoy these at home or on the road (including 1/4″ and airline adapters), and you can see the value.
Read full review @ Audioholics
Pros
  • Comfortable
  • Has everything you need for home or travel
  • Built in splitter for sharing sound
  • Compact design
  • Great sound
Cons
  • Requires batteries for best sound
  • Uneven bass
  • Controls hard to operate
  • Soft case
