Axiom Audio EP400 DSP Subwoofer Announced For Smaller Rooms
Axiom’s newest addition, the $1,100 Epicenter EP400 DSP subwoofer will launch in March!
Next month, Axiom will introduce the Epicenter EP400, a new, compact high-performance DSP subwoofer. The EP400 delivers extraordinary bass extension as deep as 23 Hz in smaller rooms such as dens or bedrooms, using a much smaller enclosure than a conventional subwoofer.
Borrowing the same DSP technology from the larger, well-reviewed Axiom EP500 and EP600 subwoofers, the EP400 uses a powerful 500-watt internal amplifier coupled to a tough long-throw 8-inch driver and custom DSP algorithm to extract maximum sound pressure levels as high as 116 dB from an enclosure barely taller than Axiom’s M3 bookshelf speaker.
Like its bigger DSP brethren, the Axiom EP400 uses a Digital Signal Processor (DSP) and “algorithm” – a custom-written digital roadmap — to model ideal deep bass extension then modify the 400’s performance to deliver real-life volume levels with powerful bass extension that exhibit excellent “linearity” or smoothness. The algorithm, which is programmed with the woofer’s specific traits, applies power from the amplifier to automatically correct any potential deviations away from ideally smooth bass response. And since its digital code also contains the output and cone-excursion limits of the driver and amplifier, it automatically protects the EP400 from being overdriven into distortion.
Epicenter EP400 DSP Subwoofer Specs
Enclosure: Bass Reflex
Max Amp Power: 500 Watts
Crossover Adjust 40 – 150
Phase 0 & 180
Woofer Size 8″
DSP Controlled Yes
Line In and Out Yes
Balanced Line In and Out Yes
High Level In Yes
Room Trim Yes
Dynamic Power Supply Yes
Anechoic Resp. +/- 1.5dB 28-150
Anechoic Resp. +/- 3dB 25-150
Room Resp. + 3dB/- 9dB 23-150
Max SPL Anechoic 106 dB
Max SPL In Room 116 dB
Dimensions HWD inches: 13.75 x 10.5 x 16.8
Dimensions HWD mm: 349 x 266 x 422
Weight (lbs) each: 48.55 lbs
Weight (kg) each: 22.02 kg
Contacted at Axiom’s head office in Dwight, Ontario, Axiom president and chief designer Ian Colquhoun outlined the design philosophy behind the creation of the new compact sub: “The EP400 was produced to fill a specific need that was being requested of us over and over. This was to pack real subwoofer performance into the smallest possible enclosure,” he said. “It was not created to be a less expensive version of the EP500; in fact, if you do not have any concern with the enclosure size, then the EP500 would be the way to go. What the EP400 enables is that the master bedroom or den can have subwoofer response as powerful as the home theater room, in an enclosure small enough to tuck in a nightstand or under the bed.”
Used in combination with any of Axiom’s compact bookshelf speakers — the M2 v2, M3 v2 or M22 v2 — or their in-wall equivalents, the W2, W3 and W22 — the new EP-400 effectively extends sound reproduction across the entire range of audible musical frequencies to levels that approach the subsonic region, and, if desired, at realistic output levels as great as 116 dB SPL.
Priced at $1,100, the EP400 subwoofer will be available in Axiom’s standard in-stock finishes — Black Oak, Boston Cherry, Light Maple or Mansfield Beech — or in our wide range of custom vinyl or real-wood finishes.
Hi-Fi Components
The venerable Canadian manufacturer has been acquired by Colquhoun Audio and joins Bryston and Axiom Loudspeakers under the family tent.
New Bryston CEO, James Tanner will manage operations and fortify relationships with A/V specialty dealers.
Save $80 by pre-ordering the new Axiom Audio AxiomAir N2 wireless speaker that's both multi-room ready and portable.
Axiom Audio today announced a Kickstarter campaign to launch a revolutionary portable, wireless, multi-room Wi-Fi speaker called AxiomAir. The $800 speaker is expected to be...
Axiom Audio today introduced their second series of computer speakers in three sizes from $500 to $658. These High Power computer speakers are based...
Axiom Audio just released their new flagship floorstanding loudspeakers, model M100, which offers more bass over the previous top-of-the line M80 tower speakers. The...
Axiom Audio announced the LFR1100 omnidirectional linear field radiating floorstanding loudspeakers designed by Audio Engineer Andrew Welker and Axiom President and Founder, Ian Colquhoun. The...
Center Speakers
Axiom Audio introduced the oversized VP160 Center Channel speaker, which is perfectly matched to their M60 tower speakers. The VP160 features the same 6.5-inch...
