Yamaha PDX-B11 Review
We’re not going lambaste the PDX-B11 and slap it with the worst...
It’s great being able to listen to music wherever you go, but it’s even better when you can stow your headphones and play your music loud and proud using a portable AirPlay speaker.
The AQ Audio SmartSpeaker is roughly cylindrical, with a tapering top that houses the power, Wi-Fi and volume controls. At the back is an auxiliary input, plus a USB port to set up the speaker to use your Wi-Fi.
Not that you have to: thanks to SmartSpeaker’s AQ Direct feature, you can connect your AirPlay device directly to the speaker on an ad-hoc basis, with no network needed. It’s very useful.
Unlike most AirPlay speakers, which have to be on the same network as your Mac or iOS device, you can stream music through AirPlay directly to the SmartSpeaker. So if you want to listen to music on the beach or at the bottom of the garden, way out of range of your router, you can.
You can also combine multiple SmartSpeakers to create a multiroom audio system, or team two so they act as the left and right speaker in a stereo setup. Sadly, iOS can only stream to one AirPlay speaker at a time, so you need to use iTunes to take advantage of these features.
AirPlay set-up was troublesome when using an iPhone 5. It should be as simple as connecting your iOS device to the speaker using its USB cable and pressing a button, but try as we might, we couldn’t get it to work using an iPhone 5 and Apple’s stock USB-to-Lightning cable. It worked perfectly using an iPhone 4 with the old 30-pin cable, and you can also set up using the AQ Connect app or a web browser.
When it comes to sound quality, the AQ Audio SmartSpeaker is a mixed bag. It delivers enough sound to fill a medium-sized room, and makes a decent fist of most kinds of music. The lack of deep bass oomph and a rather watery treble stop it scaling the heights a proper hi-fi speaker would, but it doesn’t deliver any nasty surprises either. ‘Pleasant’ is probably the best word.
By Rob Mead-Green, TechRadar
