AOC Q2963PM Review
The AOC Q2963PM is an ultra-wide, 29″ IPS LED display monitor with a 21:9 aspect ratio. That is like having two 4:3 monitors side by side. It will accept two sources and show them to you Picture-in-Picture or Picture-by-Picture. It performed admirably on our HQV tests, it has integrated speakers, HDMI and DVI input (both cannot be active at the same time), and a D-Sub or DP input for your computer. It sports a fairly innovative pivot plate that allows up to 25 degrees of movement on the stand or on a wall mount. While we did find some idiosycracies, all in all, it is an excellent monitor. The only problem is the price. At $500, it certainly isn’t cheap and you could easily pay less for two 16:9 monitors of similar sizes. MSRP: $499
(4.0 out of 5) Performance
(2.5 out of 5) Value
Read full review @ Audioholics
Pros
  • Extra Wide
  • Very bright
  • Dual source capable
  • Innovative mounting/stand options
Cons
  • Must use PC input for dual source
  • Doesn’t scale/letterbox
  • Many connections visible when wall mounted
  • Pricy
Last Updated:
More in AOC
