VIZIO VSB210WS Sound Bar With Wireless Subwoofer
Powerful Sound Performance Without the Clutter
Designed with the home theater enthusiast in mind, this universal sound bar and powerful wireless sub woofer system is for everyone and works with any brand of HDTV. Complete with cutting edge sound technologies such as SRS TruSurroundHD™ to hear rich bass and clear dialog and SRS TruVolume™ to automatically limit abnormally loud sounds like commercial breaks, the VIZIO Sound Bar System will produce an impressive High Definition Audio experience that usually costs thousands of dollars and hours of installation time to achieve. SRP $349.99.
Features:
  • Four 3″ high-efficiency mid/bass transducers
  • Two 1″ high-Performance aluminum neodymium tweeters
  • 2.4Ghz wireless subwoofer with 6.5″ long throw
  • High excursion driver
  • Remote control
Sound Bar Dimensions:
  • 39.95″ W x 4.82″ H x 4.33″ D (1015mm x 122mm x 110mm)
Subwoofer Dimensions:
  • 11.18″ W x 12.30″ H x 11.87″ D (284mm x 312mm x 301mm)
SoundBar Net Weight:
  • 7.8lbs (3.48Kg)
Subwoofer Net Weight:
  • 15.5lbs (6.92Kg)
Gross Weight:
  • 30lbs (13.40Kg)
User Manual (pdf)
HDTV 4K & 8K TV
At 86-inches in diagonal, Vizio's largest 4K TV ever arrives at the end of April for only $999.
HDTV 4K & 8K TV
Walmart has acquired Vizio and that could be good news for consumers looking to get a good price on a new TV.
HDTV 4K & 8K TV
Vizio simplifies its 2023 4K QLED TV line-up down to 5 new models, priced from $399 to $999 in 55, 65 and 75-inch screen...
HDTV 4K & 8K TV
Vizio's new TV Home Screen provides easier navigation, enhanced features, and fixes a number of issues that plagued SmartCast.
HDTV 4K & 8K TV
Owners of Vizio Smart TVs have some new remote control and mobile app features to take advantage of for 2023.
Quantum Dots are playing a growing role in TV technology. Find out what you need to know.
Ask an Expert
OLED TV technology is considered superior to LCD-based TV technology, but what is the real story?
Are you buying a new TV right now? Put down that flyer from Costco or Amazon and read this first before you waste your...
