Soundcast Melody Omni-Directional Bluetooth Speaker
Soundcast Systems introduced their newest, compact omni-directional Bluetooth wireless speaker system called...
If you’ve been following Ultrabooks, you’ll know that Intel has a bunch of perquisites before you can call the system an Ultrabook. Among these are a quick return from sleep or reboot (Intel Rapid Start Technology) and quicker startup and app launching (Intel Smart Response Technology). Both technologies are related to the requirement that Ultrabooks use SSDs as either their primary drive or as a SRT cache to help the system’s speed. Other requirements don’t depend on Intel technologies, like the thickness requirements or battery life expectations. Let’s say you were an HP buyer and you wanted to keep most of the Ultrabook’s features and form factors, but you want to save yourself up to a couple hundred dollars of purchase price? Enter the Sleekbook.
A Sleekbook essentially looks like an Ultrabook, because it is built into the same chassis. The two announced Sleekbooks, the HP Envy Sleekbook 14-inch and the HP Envy Sleekbook 15.6-inch look identical to their HP Envy Ultrabook counterparts, but as they say it is what is inside that counts. The Envy Sleekbook 14-inch eschews the Ultrabook’s 32GB mSATA SSD cache drive, but aside from that the specs are identical. They both use the same 500GB hard drive, 14-inch screen, Intel Core 2nd/3rd-generation processors, Wi-Fi, webcam, Beats Audio, and sub-20mm thickness. Essentially, the Ultrabook will boot faster and launch programs just a bit faster than the Sleekbook, but Sleekbook owners will pocket a savings of $50 (at least comparing base models). Both 14-inch systems claim eight hours of battery life. The difference and savings are a bit more pronounced with the Envy Sleekbook 15.6-inch versus the Envy Ultrabook 15.6-inch. The Sleekbook 15.6-inch comes with an AMD processor (AKA accelerated processing unit or APU) instead of an Intel Core processor. The 15.6-inch Sleekbook and Ultrabook share 4GB of memory, 15.6-inch (1,366 by 768 resolution) screens, Wi-Fi, Beats Audio (dual speakers plus a subwoofer), HP Software, light weight, and sub-20mm thickness. The Sleekbook also comes with a smaller 320GB hard drive, in contrast with the Ultrabook’s 32GB mSATA SSD cache and 500GB hard drive. It’s of note for both Ultrabooks that the cache drive is invisible to the user, it’s really there to provide fast reboots and wake from sleep functions. You’re very likely to see a performance difference between the 15.6-inch models, but we’ll reserve our final judgment until we compare both systems in our review process. Both 15.6-inch models claim a nine-hour battery life. In any case, Sleekbook 15.6-inch buyers will save $200 for the base units, which is fairly significant. That’s easily enough to add a carrying case and an external optical drive, if you feel then need to use one.
There are a few other Ultrabook technologies that Intel has kept optional (for now), including an ability to keep updating your email and social media while the system is asleep but connected (Intel Smart Connect Technology), Intel Anti-Theft Technology (security for your hardware), and Intel Identity Protection Technology (security for your digital life). We’ll have to see if these planks are also omitted from the Sleekbook platform, but for the time being they’re not even required in Ultrabooks. Needless to say, both Sleekbooks and Ultrabooks are aimed at providing the majority of users a computing experience “without comprimise” in a highly portable package.
By Joel Santo Domingo, PCMag
