Mirrorless Cameras
Samsung NX mini SMART Camera
Samsung today announced NX mini, the world’s slimmest and lightest interchangeable lens camera, weighing only 158g (body only) in an ultra slim (22.5mm) metal body with a luxurious leatherette finish. The NX mini features 75.2mm (3.0-inch) Flip up and Touch Display that flips 180-degrees, 20.5MP BSI CMOS Sensor, 6fps Continuous Shot, 1/16000 sec Shutter Speed and more. In addition NFC and Wi-Fi capabilities allow users to quickly share photos.
The NX mini has a range of exclusive features which allow photographers to effortlessly indulge in the global trend of self-shooting. With a 75.2mm (3.0-inch) Flip up and Touch Display that flips 180-degrees, users can frame images of themselves perfectly. The NX mini’s powerful optical performance provides crisp and clear, high quality images ensuring that the subjects in the photos are always looking their best. With the ultra-slim 9mm wide angle lens, the NX mini can capture group shots from an arm’s length away, so users can easily frame themselves and be part of group memories.
The NX mini offers a new Wink shot feature to take a selfie — hands-free. Users simply need to set up their shot and wink at the camera to capture an image. Once a wink is detected, the NX mini takes a shot automatically after two seconds, without having to press any buttons.
Despite its slim appearance, the NX mini packs a big performance in to its small body. Its large 1-inch type 20.5-megapixel BSI CMOS Sensor enables users to capture high quality images, ensuring no details are missed. With the highest resolution in its class, pictures captured with the NX mini burst with vivid color.
The NX mini’s impressively fast 6fps Continuous Shot mode allows photographers to take continuous shots, so every detail can be captured and no moments are missed. The fast 1/16000 sec Shutter Speed freezes fast moving scenes, allowing for the dramatic capture of motion in crisp detail, without blurring.
https://www.youtube.com/watch?v=75Oc8RpGehE
As with all of Samsung’s 2014 SMART cameras, the NX mini features advanced Wi-Fi and NFC integration that makes it seamless to share images. Exclusive to Samsung, Tag & Go connectivity allows the NX mini to pair with NFC-enabled devices, such as smartphones or tablets, simply by touching the two together. Once paired, users can:
  • Select and transfer multiple images to the paired mobile devices through Mobile Link;
  • Send images to up to four devices with Group Share, eliminating the time-consuming and repetitive process of sending pictures to multiple friends;
  • Control the NX mini via a smartphone with Remote View Finder Pro;
  • Use the camera as a Baby Monitor. When noise is detected, the paired smartphone is activated via an app, allowing parents to see if they need to attend to their child.
Additionally, extensive storage options are integrated into the NX mini and images can be uploaded directly from the camera to the cloud for an easy storage solution. Users can upload their pictures directly from the NX mini to both Dropbox and Flickr, the popular photo sharing site. Dropbox provides 2GB of free storage to new users, accessible from just about any device and with Flickr users can upload up to a terabyte of images. With all the storage and sharing technology built into the NX mini, it’s easier than ever to share and store beautiful images.
Price and Availability (April 2014)
Samsung NX mini w/ NX-M 9mm F3.5 ED pancake prime lens → $449
Samsung NX mini w/ NX-M 9-27mm F3.5-5.6 ED OIS zoom and the external flash unit → $549
Specialized NX-M Lenses for NX mini
Samsung has introduced three NX mini lenses (NX-M) which are optimized for use with the NX mini body, providing a variety of options to meet individual shooting preferences.
  • The NX-M 9mm F3.5 ED lens ($179) has an ultra-slim design and its wide angle makes it the ideal choice for those capturing landscapes and self-portraits. This lens also provides the optimum angle for taking selfies, ensuring the camera becomes the go-to choice for those looking to share the best of themselves.
  • The NX-M 9-27mm F3.5-5.6 ED OIS lens ($279) is a micro-compact zoom lens with a stylish design and is small enough to comfortably fit in pockets and bags. This compact-sized standard zoom lens offers a variety of shooting options from wide-angle to telephoto shots, with optical image stabilization for sharp results.
  • With the NX-M 17mm F1.8 OIS lens, photographers can enjoy a beautiful bokeh effect which makes the highly detailed subject stand out from the surroundings.
NX mini owners will also be able to use fifteen NX lenses with the device by using a specialized NX-M Mount Adapter (ED-MA4NXM). These lenses are sold separately.
Samsung NX-M 17mm F1.8 OIS Lens Specifications
Focal Length 17mm (equivalent to 45.9mm in 35mm format)
Elements in Groups 8 elements in 5 groups (2 Aspherical lens, 1 Xtreme High Refractive lens)
Angle of View 50.5°
Aperture F1.8 (Min. F11), (Number of Blades : 5 , Circular Aperture Diaphragm)
Optical Image Stabilizer Yes
Minimum Focus Distance 0.18m
Maximum Magnification 0.11x
Filter Size Ø39
Mount Type NX M  Mount
Dimension (DxL) 50.0 x 27.5mm
