Like
Coax to rca?
Username: Jscusbp
my coax on the back of my TV snapped, but it still has the rca hook ups. Is there a converter to go from the wall coax to an rca?
Username: Rfkiki
Hi,
It seems that you need the pigtail.What other end of the coax do you need?I mean:
The end :RCA connector:http://www.rfsupplier.com/product_info.php?products_id=1161
The other end:?
Thanks
Rfkiki
Username: Jnmfrank1
I have the same issue as JSC. The cable connector on the back of my television snapped off. I have an old VCR hooked up to it so I can use the RCA (white,red,yellow) inputs on the TV in order to still use it. Does anyone know of an adapter or cable that will allow me to go from the cable wall outlet directly to the RCA (white,red,yellow) inputs? Thanks !!
Username: Rfkiki
Could we know the pics of the RCA INPUTS on your TV?
Username: Mybut1384
Grapevine, TX USA
There are two ways for coax to RCA. You can use VCR device for converting coaxial to RCA. You need to connect coaxial cable to VCR and RCA output of VCR connected to your back of tv. The other way is you need a coaxial adapter that convert your coax cable to RCA without any hussle.https://www.bestcablesplitter.com/how-to-convert-coaxial-cable-to-rca/
Top Deals
Loading, please wait...
Need to Register?
Forgot Password?
Enable HTML code in message
Facebook
Directory
Top Deals
