Ford 6000 cd code
Username: Mirado
Post Number: 27
Hello. I need code for ford 6000 cd.
Model. Single cd-kw 2000
Serial V 039339
Thanks...
Username: Iwos
AZERTY
Post Number: 3490
mirado
Username: Mirado
Post Number: 27
Hello,
Unfortunately the " V " series codes aren't available for free anywhere on the net, you will have to contact your local dealer.
Otherwise see here -- > https://www.onlineradiocodes.co.uk/ford-radio-codes
Username: Kmarv
Recently serviced my Ford Ka 1.3. The radio (6000CD) displays LOCKED 3 and i have pressed buttons 1, 3 & 6 and it briefly switched on for about a 30 seconds then it locks again. What could be the reason
Username: Jiikonen
Hi!
I had to remove the radio from my son's Focus when I fixed the broken AC blower switch, and unfortunately the radio code is long long gone...
The car model is Ford Focus /2001 and the radio is 6000CD
The serial number of the radio is M127079
Could you please find me the unlock code?
Username: Eve1990
Post Number: 989
juice
Username: Jiikonen
code is 4067
If you would like to support the activity of the page,
you can leave a quick tip via paypal.
mail Eve28021990@yahoo.com
Many thanks
Username: Jiikonen
Lovely!
I'll check it out soonest!
Username: Jiikonen
@eve1990, the code worked like a charm!
Shall I donate to your mail address?
Username: Jiikonen
Hi Eve, justsent couple of bucks your way.
Take care
Username: Jonl83
Dublin, D Ireland
Hi guys
Just wondering if anyone could help me with a radio unlock code for a 2006 ford focus 6000 cd radio serial number is M235813
Thanks in advance guys
Username: Iwos
AZERTY
Post Number: 3739
JonL83
Username: Jonl83
Dublin, D
Ireland
Hello,
And if you are satisfied with our services, do not forget a small donation through Paypal.
Paypal e-mail address : c.r.t.m.auto@gmail.com
Your code is . . . . 9126
Contact : c.r.t.m.auto@gmail.com
Many Thanks
