Clarion radio code required
Username: Oneskimjim
Hi I have a customers 306 and when we disconnected battery lost radio code. There is one in the manual which I have entered but it doesn't wrk. Please help!!!
CL0401Y0191704
PU-2294A
Thanks
Username: Tech13
Post Number: 731
OneSkimJim
Hi,
Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing.
(Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio.
Username: Thecitykid
HI there,
i need radio code for my vw japan. its clarion
serail number 0020357
model : JOVAE2JP7A1
BAR CODE : QY-7325V-B 0020357
THANKS VERY MUCH
Username: Tech13
Post Number: 737
oozy
Hi,
sorry we can't help
Main Dealer or a Decoding Service only for this code
Username: Ashgunnell
Hi there code needed for
PU-2294A
SERIAL CODE:
C7000006356
THANKS
Username: Tech13
Post Number: 760
Ashgunnell
Hi,
Try..... 1524
Username: Sword80
hi,
i need radio code clarion radio wxz468rmp . Pe-2758E
please help
Thanks
Username: Camel131
Post Number: 74
sword80
Username: Sword80
hi
Sorry....your code will only be available from someone with access to the Main Dealer database or the unit will have to be taken into a Radio Decoding Service
It is unlikely to be available for free from anywhere on the Internet
maelysclavel@gmail.com
