Cable / Male Plug for Blaupunkt cdc2
Username: Jar22
Hi All, I installed a phillips ccr600 in my opel and i have a Blaupunkt cdc2, 6 cd changer to install too. have both codes for the head unit Philips ccr600 and the cd changer. I know the pinout connections to connect the two units. What I dont have is the cable/male plug to connect both, i only need the plug for the Blaupunkt cdc2 unit (Ref. 7607775320 - 90462566 - W1G)
Does any one know where I can get this cable/male plug ?.
Best Regards.
Many thanks in advance,
JAR22.
