Citroen dispatch code
Username: Johnnyseven
hello all
im looking for a code for my radio after changing battery
if any one can help me i would be very grateful
the serial number is cl040161027029c
the barcode number is c70000001336
cheers
Username: Tech13
Post Number: 278
johnny
Hi,
Try.....2564
thanks for the quick response TECH13
i will try that code in morning and let you know
cheers
Just to let you know that the code you gave me done the trick
Your a star
Thanks again
