Radiocode Grundig 3880 RDS Infomat
Username: Hansdambf
Hello,
I would be very pleased if anyone could
help me to get the code for my car radio.
After several years I want to install it again was searching it again
and as it is bigger than the code card,
I found the radio and the only I can
remember, is that I have put the code card
anywhere else - as recommented.
WKC 3880 RDS 9.18204 G HB 0B-0
GR0608N1149570 072
Username: Iwos
Post Number: 1203
hansdambf
Username: Hansdambf
Hello,
TRY CODE .. 7188
Username: Hansdambf
Everything works fine.
Thank you very much for your help
