New member Username: NeilsnookercarpPost Number: 1 Registered: Apr-15 | can anyone help please i think this is the serial number gm330886636 thanks for any help |
Silver Member Username: Decode_radioPost Number: 692 Registered: Jan-14 | neil New member Username: Neilsnookercarp Post the 14 character Serial Number beginning GMxxxxxxxxxxxx found stamped in the metal casing contakt me http://forum.kody-radio.pl |
New member Username: NeilsnookercarpPost Number: 2 Registered: Apr-15 | hi these are all the numbers on the back of the radio thanks gm330886636, no 13122932 type cdr 2005 (e) 90123000028500 00303272507835 bs000327, rcd452-01 |
Platinum Member Username: RegroosterPost Number: 11772 Registered: Aug-08 | #neil Sorry....your code will only be available from the Main Dealer database or the unit will have to be taken into a Radio Decoding Service It is unlikely to be available for free or cheap from anywhere on the Internet |
New member Username: NeilsnookercarpPost Number: 3 Registered: Apr-15 | thanks all for the info |
