Re
Username: Dritong
i need help please with my autoradio:with code
type: Trafic Pro
Model:4720
Serial no: 25112157
Username: Iwos
Post Number: 515
dmg70
try code .. 34461
Username: Dritong
sorry but i dont see other numbers here on my stereo are 7 digit's and i got only 5 ALMAIDA
Username: Iwos
Post Number: 516
dmg70
Code Entry as Follows:
Switch Radio On - Display Shows
" BECKER " Followed by " CODE * * * * "
Enter CODE in the order it is read:
For Example, to Enter Code 12345
Press Preset 1 then 2 then 3 then 4 then 5
The Code will Enter Itself Automatically
Username: Dritong
ahaa wich it means my code is 34461 the rrest of numbers to leave empty im i right or plan B i shuld just give 1 2 3 4 5 6 7 and is okthat will doo right becouse i dont dare to push any number without beeing shure 100% thanks for anderstanding.
