Nisan Micra K12 Radio Code
Username: Chimpongas
Hi,
Please can someone help me with the code for my 2005 Nisan Micra K12 radio.
Model: BP3349 5 8135559
Serial number: 7 643 349 318
Thanks, Dave.
Username: Iwos
Post Number: 500
Dave
Hi,
TRY CODE .. 5176
Thanks Almaida, that worked perfectly
You have saved me from going mad with a silent radio.
BRILLIANT!!!
Username: Tebo_83
Hiya im looking for a radio code for my micra 03 k 12
Bp number
Bp234631958522
Thanks
Username: Titanum123
Post Number: 838
tebo
Username: Tebo_83
try code 3207
Username: Frankold
Please help me! I have to be a micra months and I find the code for the car.
I disassembled the car radio and I found these codes:
BP234746065844 one hand
M5X6MM from the other side.
Please help!
Username: Iwos
Post Number: 593
frankold
try code .. 2126
Username: Frankold
THANK YOU !! FANTASTIC ALMAIDA ! works perfectly !!! you are great! REALLY THANKS!
Username: Margaret68
Can anyone help he i have a nissan micra s 2005 and i cant find radio code for it only numbers i can find on radio are K122059557 and 588ed2b49806 and 23095215
Username: Dekster
POLAND
Post Number: 1997
margaret68
Remove the radio from the car and after all the letters and numbers on any of the labels, bar codes, and stamped metal body.
contact me: http://koddoradia.pl/
Username: Naka78
Please I need code for Nissan micra 2004 patrol 1.4 manual 5door I just changed battery now radio asking for code please can you help
Username: Decode_radio
Post Number: 475
Ali
Username: Naka78
contakt me http://forum.kody-radio.pl
