Renault Laguna 1.9 dci
Username: Hadzolaguna
Hi,
If you would be so kind to help me also with my radio,
Namely I I have a renault laguna:
Model No: 22DC258/62B
TOA851
RN258F10073271
Prod No: FD0101260073271
Thank you very much :-)
Username: Iwos
Post Number: 475
hadzo
Hi,
TRY CODE .. 0331
Works :-D
Thanks again!
Username: Kikisilja
Hi,
I need code for my Renault Laguna
model NO: 22dc279/62z
TOQ487
RN279f10176467
prod. NO: FD0201450176467
Thank you!!
Username: Titanum123
Post Number: 824
meho mehic
Username: Kikisilja
try code 9575
Username: Bratsusi
Hello,
I need code for BMW Professional RDS
Serial no BE2450S1001999
Thanks a lot,
Stefan.
Post Number: 825
bratsusi
Username: Bratsusi
Try code 8797
Username: Kikisilja
hvala jarane!!! ;)
Username: Bratsusi
THANKS MAN, YOU ROCKS!!!
Username: Bratsusi
hvala brate :- D
Username: Jabadabadu777
I need help code for my radio Laguna 1.9 dci serial no VF1KGRE0530246339. THANKS
Post Number: 831
jabadabadu
Remove the radio from the car and after all the letters and numbers on any of the labels, bar codes, and stamped metal body.
Username: Ismailjashari
Hi
Can somebody find me the radio code
serial number
8200292329T
and
G928-Security
Many thanks
Post Number: 839
MAGismo
try code 5297
I removed radio and this is numbers
model no RENRDW100-10
T133 Security RNRD0130141404
PROD No FD0203520141404
bar code 8200247962TT133
under bar code 8200 247 962 --A
many thanks
Username: Dekster
POLAND
Post Number: 1978
jabadabadu
CODE 6886
contact me: http://koddoradia.pl/
i try that doesnt works
Username: Dekster
POLAND
Post Number: 1980
jabadabadu
Code Entry as Follows:
Switch Radio On - Display Shows
" 0000 " with the 1st digit flashing
Rotate " Thumbwheel " For Correct Digit
Press " ¬ " On The Stalk Control To Enter
If the correct code number is now shown
Press And Hold " ¬ " Until A Beep Is Heard
I accidentally typed wrong numbers and confirmed and now radio isnt working. It shows ERROR. I restarted computer and it still shows Error.
Is there a way to reset radio?
Help please
its ok I resolved problem thanks a lot
