Blaupunkt cd player code
Username: Sammyd76
BucksUnited Kingdom
Hi everyone. I have just got a cd player to go
in my fiat punto Mk2 2003 car.
I need a code for the cd player.
Blaupunkt cd player
BP137623246842
7 641 376 316
E1 021613
Hope someone can help, would be much appreciated
Thanks
Sam
Username: Iwos
Post Number: 403
Samantha Wiseman
Username: Sammyd76
Hi,
TRY CODE .. 6515
Username: Sammyd76
BucksUnited Kingdom
Thank you Almaida, I will try this code. thanks for a quick response!
Username: Manos
Hello to everyone .
Please i need a code for Blaupunkt Philadelphia
SCD09 Serial number BP9950B1907526
7 649 950 013
Thanks
Manos
Username: Titanum123
Post Number: 802
manos
Username: Manos
try code 7602 or 1602
Username: Iwos
Post Number: 443
manos
Hello,
TRY CODE .. 1602 OR 7602
Username: Manos
Thank you i will try it and i tell you
what happen.Thanks once more for your time.
Regards Manos
Username: Manos
Hello again as i put the codes but seems that
make something wrong ,please tell me when i put the code what other button i must press to open
the radio i am speaking for
SCD09
Sorry for the trouble Regards Manos
Username: Iwos
Post Number: 446
manos
Try,,,
Code Entry as Follows:
Switch Radio On - Display Shows
" Cod "
Press Preset " 1 " and the display will show
" 0 0 0 "
Press preset " 1 " repeatedly for 1st Digit
Press preset " 2 " repeatedly for 2nd Digit
Press preset " 3 " repeatedly for 3rd Digit
Press preset " 4 " repeatedly for 4th Digit
If the correct code number is now shown
Press RH Tuning Button " > " to Enter
Username: Manos
I do this way but no luck when i press the RH
tuning button the radio return to 4(dashes)any other suggestions please? Thank you
