Philips Radio Code
Username: Mrpolska
Hi,
Can I plase have the radio code for a Philips 22RC200/35?
Prod no: FD1101472973823
SN PHACFF19273823
Ref Citroen: 96 392 192 8002 PHF9273823
thank you so much!
Username: Iwos
Post Number: 261
MrPolska
Username: Mrpolska
Hi,
You must give us a security code that is somewhere on a label stuck on the radio.
example; TOV321
Username: Mrpolska
029018? e2? 28970? Those are the only other numbers on the unit! I truly appreciate your help
Username: Iwos
Post Number: 262
MrPolska
hi,
Sorry....your code will only be available from the Main Dealer database or the unit will have to be taken into a Radio Decoding Service
It is unlikely to be available for free or cheap from anywhere on the Internet
Username: Mrpolska
Alas! Thank you for your help, you are a legend!
