Peugeot 206 radio code , please help
Username: P206rad
hy there
i need youre help please ,
after removing the battery from the car ,now the radio ask for its code , wich i dont have
if anybody can help me with it , please
its a peugeot 206
radio : PHILIPS MODEL : 22RC200/65S
CODE : T0W550
PROD NO : FD0100240017062
thanks in advance , Upload
Username: Iwos
Post Number: 171
rad
Username: P206rad
Hi,
try code .. 3452
Username: P206rad
for the moment i get the 7 error screen , i think i have to wait for an hour or so , in order
to be able to try to introduce the code again ,
later i will confirm
Username: P206rad
it worked ,
thank you , thank you , thank you
Username: Gezzer
I need the code for my radio
model 22rc280/65s
tox000
prod fdo502240382969
vdo rd3-00
vdapof20382969
ref.peugeot:
96 451 459 7700
vdo0382959
Username: Titanum123
Post Number: 718
gerry
Username: Gezzer
sorry we can't help
Main Dealer or a Decoding Service only for this code
This Radio is VIN CODED to the vehicle, and does not require an additional code number.
Username: Annie_bsb
I need a code please:
SIEMENS VDO RFM-1 MP3
96 636 632 XT
HC5807420009531
VDAPMF0009531
SW: D5D1 / HW: 1100
k379 - SECURITY
Username: Iwos
Post Number: 304
ana rodriguez
Username: Annie_bsb
try code .. 5347
Username: Annie_bsb
it did not work
Username: Regrooster
Post Number: 11754
#Annie_bsb
5347 is definitely the correct code for the number quoted
k379 - SECURITY
Make sure you press the final button that stores the code for at least 10 seconds
Username: Rodrigobonela
Hi Guys,
My radio RFM1 is showing the message: WAIT.
However, I wait many minutes and it didn't change.
Anybody could please help me?
Thanks
Username: Migo81
Hello, i need the code for my radio Philips
Model No 22RC200/65s
TOI263
PROD No FD0300510136630
Thanks!
Username: Iwos
Post Number: 367
motronic81
Username: Migo81
Hi,
Try code .. 1351 ou 3552
Username: Migo81
Thanks!
It worked.
Username: Dinoeu
96 657 391 XT
HC5808440010020
VDAPMF0010020
SW: D5D1 / HW: 1100
k912 - SECURITY
Username: Decode_radio
Post Number: 437
dinoeu
Username: Dinoeu
CODE 4174
contakt me http://forum.kody-radio.pl
Username: Nasir_kwa
Code for Blaupunkt Peuguot 206 N2 Needed please
Serial:
Peugeot T1 Niv2
7 648 146 392
BP8146Y5921825
Side serial:
8 635 132 688 07
st 02-Z-275-NA
Sticker:
96 370 825 80
Username: Iwos
Post Number: 601
nasir_kwa
code .. 3453
Username: Nasir_kwa
Worked Like Charm!
You da man ALMAIDA
Thanks.
Username: Jluis
Niteroi, Rio de Janeiro Brazil
Hi,
No one could unlock my radio, in Rio de janeiro!
Please, help me.
96 636 632 XT
HC5807430010156
VDAPMF0010156
SW: D5D1 / HW: 1100
L060 - SECURITY
Post Number: 937
Luis
Username: Jluis
Sorry....your code will only be available from the Main Dealer database or the unit will have to be taken into a Radio Decoding Service
It is unlikely to be available for free or cheap from anywhere on the Internet.
Username: Gogui
hi, can you help me with my stereo CODE?
Siemens VDO RFM-1 CD
96 636 633xt
HC5708030010187
VDAPMF0010187
Thanks a Lot!
Username: Dekster
POLAND
Post Number: 2028
Seba
contact me: http://koddoradia.pl/
Username: Flaviotstma
Hi, need a code... help..
96 657 391 XT
RFM-1 MP3
HC5809150017362
VDAPMF0017362
SW: D5D1 / HW: 1100
S981 - SECURITY
Username: Iwos
Post Number: 765
Flavio Rodrigues
Hello,
S981 - SECURITY .. Try code .. 7009
ALMEIDA
Username: Iwos
Hi!
This code doesn't fix the problem.
What do i do?
Username: Iwos
Post Number: 791
Flavio Rodrigues
Hello,
Sorry
Not the same security code.
RADIO PEUGEOT - CITROEN VDO RFM-1 MP3
MADE IN BRAZIL.
Not possible for radios BRAZIL.
