Nissan radio code
Username: Pugzo
hallo can you help me please with my nissan primera radio code. i unpluged battery because airbag light was flashing and my radio is locked
s.n. CL053420107568
PN-2419F
I dont know what else you need to help me
Username: Decode_radio
Post Number: 53
Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your
radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing.
(Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop
to read/recode the memory chip (EEPROM) inside your radio.
contakt me http://forum.kody-radio.pl
Username: Pugzo
any other chance to get the code?
Username: Annly
Hello,
I need radio code for my Nissan Note 2006. Can anyone help me with that?
BP538962404330
7645389318
Ordered code from www.radio-code.co.uk but it didn't worked
Username: Titanum123
Post Number: 441
Anneli
Username: Annly
try code 1498
Username: Annly
It works!!!
Thank you so much!
Username: Stevemikedgmailcom
hiya.need your help.code for nissan navira radio.serial number CL065950022329.my email address stevemiked@gmail.com.cheers
Post Number: 479
steve
Reminder :..NO MULTIPLE CODE REQUESTS ON THIS FORUM
Single free code request for personal use only (one code request every 6 months minimum)
This is for security reasons in order to prevent abuse by traders+dealers, car radio thieves and other chancers
Sorry if you are one of the honest ones !
Username: Cazd
Hi
Please can you help
I need a code for a Nissan Micra radio as locked out due to disconnected battery
BP334936399206
7643349318
Many Thanks
Caz
Username: Dekster
POLAND
Post Number: 1662
Caren
Username: Cazd
CODE 1098
contact me: http://koddoradia.pl/
Username: Cazd
Dear Dekster
Many thanks, it worked
Caz
Username: Stevemiked3gmailcom
hi need help.my radio request code.serial number CL065950022329.hopely somebody can help me.god bless you.
Post Number: 499
mattia
Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing.
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio.
http://www.forum-auto.com/pole-technique/equipement-automobile/sujet395936-5460. htm#t14836864
