VT-12 vs Rocket Tykes vs Athena speakers
Beth
I bought ONKEYO TX-SR601 and I am considering buying new speaker system. I am considering HSUResearch VT-12/STF1, Onix Rocket Tykes 5.1, and Athena Mecra 6. The Living room is 16 by 14. I would appreciate if someone can compare or recommend one of these system.
Username: Project6
Post Number: 1318
Definitely the HSU and Rockets, much better than the Micras.
Beth
Thanks Berny. Do you know which one of (HSU or Rockets) matches better with TX-SR601? Also, if you would compare them or recommend one of sustems? I will use the system for music and movies(50/50)%. Thanks
Username: Project6
Post Number: 1322
I would go with the HSU VTF-2 mk 2. What is your budget on the other speakers? Because I like the ELT series and it comes with a subwoofer for $999.00
Beth
Around $500.00 and I need small speaker since I am living in apartment. Thanks
Username: Project6
Post Number: 1326
AV123 is having a special on the Rocket Tykes for $499.00 with a Receiver. That is one great deal!
