I need some help deciding, Should i get the Pioneer VSX-43TX or the SOny STR-DA4es...I can't decide, there is always the harman kardon 520 could somebody help...
If you really are looking for advice, save your money and pop for the H&K, its all about power and signal clarity; the H&K has more in probably both categories, even tho the HK is rated at 75wX5, and say the sony is 120X5, the Sonys put out dirty signals, the HK will destroy it - shatter glass if you have good speakers
