Paradigm and yamaha
I was just wanting to know what you people thought of paradigm speakers. I'am considering buying theses speakers, and running them off of my Yamaha rx-v1300 reciever. Is this a good relationship or not.
elitefan
Paradigm and PSB are the only brands I would consider with Yamaha. Yamaha's need a mellow speaker to counteract the Yamaha brightness. You won't do any better with your 1300 than Paradigm.
Larry D
Elitefan, on the same note, would you also recommend Paradigms with the Denon 3803 since it too is a "bright" reciever? I need to upgrade from my KLHs.
elitefan
Larry,
Paradigm would be a great choice with a Denon. I had a Denon 2802 and liked it but hated my "upgraded" 3803. I had a pair of Paradigm Atoms for my kitchen that sounded good with the 2802. PSB would be another that would be ok with Denon. Go hear the Paradigm Monitor series and I think you'll like what you hear for the money.
turbowagon
Elitefan, what about Paradigm speakers matched with a Marantz 7300? Good combo? Thanks. :-)
