Marantz / Monitor Audio Impedance Matching
I understand impedance spec of Marantz receivers is 8 ohm while impedance for Monitor Audio speakers is at 6 ohm.
Will there be any mis-matching or overdrive?
Comments anyone?
SAL
Its OK, Marantz can power 6 Ohms speakers as well.
elitefan
Marantz and Monitor is a perfect combination. If you are considering this match you can't do any better IMO>
