Like
Need your suggestion to buy a TV sound system.
Username: Kathyjhall
Hi Everyone,
Our tv sound system was damaged last week, and we are planning to buy a new one.
We need a tv sound system that sits directly under TV and delivers better sound with a single connection and it will be convenient if it have easy bass adjustments and low weight. Our neighbor bought bose® solo 15 tv sound system from a shop called Bay Bloor Radio, and he said it contains all the criterias which I specified. Before making a decision I want to know your opinions about it. If any one had this bose® solo 15 tv sound system in home, then please post a review here.
http://www.baybloorradio.com
Username: Jan_b_vigne
Dallas, TX
Post Number: 18048
Opinions on Bose products vary, just as opinions on any one brand are variable through out the mass market. Generally, when someone is shopping for a new AV component there are considerations beyond audio performance. The best thing I can tell you given the information you've provided is to go shop for a soundbar. The price and the performance of soundbars covers a wide range from low end to high end companies producing such products.
Username: Magfan
Post Number: 3238
One thing for certain.
Soundbar quality and 'fidelity' goes up drastically with cost. Some have optical input which you run FROM sets with optical OUT. Wireless sub is a plus but you better check out adjustibility beforehand.
Going for an audition / listen beforehand AND knowing what connections you have available will save lots of downstream nuttiness.
Need to Register?
Forgot Password?
Enable HTML code in message
Facebook
Shop Related Deals
Directory
