H/K AVR 525 and 4Om speakers
Dan
I have 4Om Axiom speakers. Does anyone know if Harman Kardon 525 can handle 4Om?
I've had some problems with older recivers and 4Om speakers. Any advice would help
Thanks.
G-Man
Your lucky day. I received the following e-mail from Axiom a couple of weeks ago.
Hello Greg,
The H/K AVR525 will drive the M80tis with ease. In fact, H/K and Denon are the only receiver brands that I recommend for the 4-ohm M80s (other brands either shut down, overheat and shut down, or limit current output severely into 4-0hm loads).
I use the H/K AVR525 and it drives my M80s and M22ti's with no problem. Ignore the warning on the back (Use 8-ohm Speakers). The H/K amps are stable and robust into lower impedances.
Thanks for your interest in Axiom!
Cordially,
Alan Lofft
Axiom Resident Expert
While I am sure there are many other receivers that would be fine--since he has already had the acid test with the HK--it would seem to get a big thumbs up.
Good luck.
Dan
Dude,
that's a good news!!!!
Thanks a lot I'm so glad!! You MADE my day.
