Like
New hifi system advice
Username: Seanism
Hi all, I'm new to hifi and here
So just want some advice on getting the right system pls.. I don't have any kind of system at all at the moment. Just a set of desktop speakers.
so I'm looking to spend about £500 to £800 on a full system, with av, amp etc, do i go for am AV package or buy them seperately pls?
Found one shop called superfi and another called audio affair, pretty much the same hi-fi they sell. any recommendations? thanks
Username: Superjazzyjames
Post Number: 1672
Well, I would first recommend buying your gear seperately. HTiB (home theater in a box) systems are garbage IMO. By a "set" of speakers, I assume you mean 5 or 7 speakers and a subwoofer? To get a complete home theater system in your price range, which is roughly $750 -1200 U.S., will be a little tight. If you can expand that budget, great! If not, here is one suggestion:
Start with either a Denon, Pioneer, Onkyo or Marantz receiver (which ever sounds best with your speakers) and a decent blu-ray player. You'll want to use decent inter connect cables, not the ones that come with your blu-ray player. Rockfish, Blue Jeans, Monster, Audio Quest all make great cables. Rockfish & Blue Jeans are probably the cheapest and just as good as any others. For speaker wire, the cheapest 12 awg you can get.
After getting started with this, you might want to add other source players later on.
Let me know if this helps. I suspect that there will be further discussion.
Username: Nency
Post Number: 200
This post is very nice and very informative post really i like this post and its a really useful to us.. Pls more submitting i shared to my facebook friends...
Thanks for...
Username: Edison
Glendale, CA US
Post Number: 947
What speakers do you have?
If they are decent, you can build on them with these excellent sounding mini systems - if not, you may want to consider them with speakers (links on the bottom).
http://www.richersounds.com/product/mini-hifi-systems/cambridge-audio/one+/camb- oneplus-sys-sil
http://www.richersounds.com/product/mini-hifi-systems/denon/dm38dab/deno-dm38dab -blk
http://www.richersounds.com/product/mini-hifi-systems/yamaha/crx550/yama-crx550- sil
http://www.richersounds.com/product/mini-hifi-systems/marantz/mcr502dab/mara-mcr 502
They received excellent reviews from the pros on Hifi Magazines.
They sound better than some full sized system, that is not matched well.
If your speakers are good, they will sound surprisingsly good - better than 97% of other mini systems you heard on the market.
http://www.richersounds.com/package/system-savers/mini-hifi-systems/pah01208
http://www.richersounds.com/product/mini-hifi-systems/arcam/solo-mini-muso/arca- solo-mini-muso
Let us know what speakers you have, and let's see if they are worth building on them.
You can get decent sound for not so much money these days, if you choose wisely. Go slow and ask questions like you are doing already, b4 buying.
It would be best if you lived near a city where you can hear these systems your-self b4 buying them - you got to like them, no matter what others say.
Happy hunting...
Need to Register?
Forgot Password?
Enable HTML code in message
Facebook
Shop Related Deals
Directory
