Silver Member Username: SmwickB.C Canada Post Number: 267 Registered: Dec-07 | Anyone build any good stands? Here is a link to solid looking speaker stand. What do you think? http://www.tnt-audio.com/clinica/stubby_e.html |
Platinum Member Username: NuckPost Number: 15576 Registered: Dec-04 | I got great mileage from cement slabs and tilts Steve. The DIY stuff is great, yes? |
Silver Member Username: SmwickB.C Canada Post Number: 269 Registered: Dec-07 | If I end up with monitor's, I will give the DIY stands a try first, just for fun. Nuck what are tilts? |
Platinum Member Username: NuckPost Number: 15581 Registered: Dec-04 | Tilts are rigid parts of the stand that allow you to lean back, reliably, low mounted small speakers. |
Silver Member Username: SmwickB.C Canada Post Number: 270 Registered: Dec-07 | Right, I understand. |
Gold Member Username: DmitchellOttawa, Ontario Canada Post Number: 4436 Registered: Feb-07 | |
Silver Member Username: SmwickB.C Canada Post Number: 272 Registered: Dec-07 | David, those are pretty heavy duty looking stands. What are they made from? I think it's pretty safe to say that they are sand filled as well. |
Gold Member Username: HawkbillyNova Scotia Canada Post Number: 1106 Registered: Jul-07 | My stands are DIY but I need to build a new set. The ones I have got broken in transit, and the repair job I did on them doesn't look so pleasing to the eye. I've waiting though as I've been contemplating a speaker purchase. Thanks for the ideas. |
Gold Member Username: DmitchellOttawa, Ontario Canada Post Number: 4439 Registered: Feb-07 | Hey Steve, The bottom plinth is a ceramic tile, then a concrete block. The upright is 4" ABS pipe (filled with sand), then the top is a piece of MDF. All glued together with Bulldog Superglue. Each stand weighs about 50 lbs. |
Silver Member Username: SmwickB.C Canada Post Number: 273 Registered: Dec-07 | David, did you tie the top plate to the bottom plate with a thread rod or just the glue like you mentioned? If thats held together with just the glue it must be incredible stuff. It's hard to tell from the photo but it looks like everything is painted black. |
Gold Member Username: DmitchellOttawa, Ontario Canada Post Number: 4440 Registered: Feb-07 | Just glue. I used this stuff: http://www.rona.ca/shop/~adhesive-pl-premium-construction-adhesive-lepage-bulldo g-grip-34633_lepage-bulldog-grip_paint_shop It's crazy stuff... sorta a running joke with me and my friends. I use it to glue just about everything together. Yup, it's all spray painted black. |
Silver Member Username: SmwickB.C Canada Post Number: 274 Registered: Dec-07 | Ok, thanks David. |
