BOSE LIFESTYLE 5 Broken
Username: Agatto2
NFUS
I have no Idea if this is the right place to post this.
I have an older base 5 bose system. The base seems to be ok after I got the cd lens to stop sticking.
The problem I am having is with the sub-woofer system. The numbers are A5Pe0Du123971 and C9646
When I power on nothing happens. I happened to be able to prey
the case off (WTGF Bose) to get a look on the inside Every thing
looks pretty good good as far as the circuit board goes , fuse is
good and all the wires look connected.
So I am looking for a trouble shooting guide - Does anybody have
one or know where I can get one.
Or maybe someone can get me started on the transformer trouble
shooting to start.
tony
Username: Exerciseguy
Fort Hamilton, NY United States
Post Number: 3356
May I suggest...http://www.bose.com/controller?event=view_static_page_event&url=/customer_servic e/owners/faq/product_faq5.jsp
Username: Edison
Glendale, CA US
Post Number: 944
Don't open the section with an amp in it !!!
It can discharge electric shock even with the power chord off.
Take it into a shop, or better yet, if you can afford it, get a real Hifi system - Bose is not Hifi.
Username: Agatto2
NFUS
Thanks Christopher Molloy - But useless as they have no trouble
shooting skematics there
James those shockers are called capacitors. I will be super careful
thanks for the heads up.
Now does anybody have some DIY Repair Info on these? Where is Mark Burgess from this post? He has the info I need ?
https://www.ecoustics.com/cgi-bin/bbs/discus.pl
Tony
Username: Nuck
Post Number: 15411
Tony, only Mark or the great pumpkin can save you now.
If you find Mark, please give him my regards.
Jamie
Username: Agatto2
NFUS
Hi Nuck - I know I was hoping he would see the batsign and hit me up, as for the great pumpkin its not his time yet.
His PM is off which I can well understand. Anyone? anyone? Burgess?
Has anyone else received the schematics for this system? My model is1059-b and seriel is00a 00016. The system is not actually mine but an older friend that has fond memories and wants to keep the system working.
Tony
Post Number: 3358
Is door stop two words or one?
Username: Gavdawg
Albany, New York
Post Number: 1585
Those acoustimass cubes (if caulked) could also be used as a coffee mug.
Username: Agatto2
NFUS
Come on ---- Does nobody have the schematics for these?
efffffffff
Does anybody have any KungFu for these?
