Adapt 3.5 output to bare wire speaker
Username: Fishyy
Sterling hts., Mi Usa
Anyone know how to hook up two bare wire speakers to a 3.5 audio output from the tv?
Username: Edison
Glendale, CA US
Post Number: 923
You need an amp in between the TV and the speakers.
It can be a receiver as well - receiver is an amp with a tuner (radio).
What are the speakers you had in mind ?
Also what is your budget ?
http://www.accessories4less.com/index.php?page=seek&id%5Bm%5D=&id%5Bq%5D=8555
Something like this will work.
Then you just use a cable like this to connect the TV to your amp :
http://www.amazon.com/Belkin-7-Foot-Stereo-Link-Cable/dp/B0001OQTLY
Of course you need some regular speaker wire to connect the smp to the speakers. This one is a good sounding one - a cut above the regular radio shack wires :
http://www.accessories4less.com/make-a-store/item/IXOSXHS606WDISCOLORED/IXOS/Xhs 606-15-Awg-Gamma-Geometry-Speaker-Wire-White-SINGLE-10-PIECE/1.html
It's for a 10 feet length - is that enough or do you need more? You can find more of the same on the sight.
