It'll work. You'll know if you turn it up too loud. Wattage ratings of speakers are meaningless. Just don't run it into distortion...THAT will damage the speaker. In general, too little power is more of a problem than too much.
If you can believe the posted sensitivity number, 100 watts should put you out of the room.
