New member Username: Techno_kingHampshire, IL United States Post Number: 1 Registered: Apr-10 | I recently received an onkyo tx-sv 525 a/v receiver. I understand it's more designed for home theater scenarios but since it was free i figured i'd take it and use it as a stereo. Unfortunately I do not have speakers for it. Basically a friend bought a new receiver and just gave me the old one. Whats a decent pair of speakers for around $300 that would sound good with this receiver? |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 14819 Registered: May-04 | . https://www.ecoustics.com/electronics/forum/home-audio/535728.html |
Gold Member Username: DmitchellOttawa, Ontario Canada Post Number: 3819 Registered: Feb-07 | Paradigm Atom v5 or v6. http://www.stereophile.com/standloudspeakers/907para/ |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 14820 Registered: May-04 | . About how much volume do you require and for what sort of music? |
Gold Member Username: MagfanUSA Post Number: 1107 Registered: Oct-07 | Any fans of the small NHT? http://www.audiovideologic.com/nht.php The small one will go 300 the pair, free shipping and I guess someone will want sales tax....... Than you'd be into some stands..... |
Silver Member Username: Vm8444TorontoCanada Post Number: 176 Registered: Aug-05 | dom besides mission for the money even the m31i how about these best bang for the buck. review |
Platinum Member Username: NuckPost Number: 14929 Registered: Dec-04 | What size is the listening space, and can you bring the speakers out into the room, space wise? Is the speaker location dictated by space/compromise? |
New member Username: Techno_kingHampshire, IL United States Post Number: 2 Registered: Apr-10 | The room is actually just an empty storage space in a barn, me and a couple buddies just hang out and throw parties in it. it's an all wood barn, dont know how much affect that can actually have and its about 40X40X25. we listen to pretty much anything but a mojority is spread out between some rap, techno, and rock. |
Gold Member Username: DmitchellOttawa, Ontario Canada Post Number: 3823 Registered: Feb-07 | Man, that's a big space. You're gonna need more than a couple of Paradigm Titans, lol. Maybe some PA speakers? |
New member Username: Techno_kingHampshire, IL United States Post Number: 3 Registered: Apr-10 | I did some research around the net and i found these: http://www.buy.com/prod/new-home-pa-dj-karaoke-bookshelf-black-pro-audio-two-way -speaker-pair/q/listingid/46669307/loc/101/211479956.html i know they're on the cheaper side but would they do the job with a decent quality sound |
New member Username: Techno_kingHampshire, IL United States Post Number: 4 Registered: Apr-10 | also would that receiver be able to power this sub: http://www.onlyfactorydirect.net/servlet/Detail?no=94 |
Gold Member Username: DmitchellOttawa, Ontario Canada Post Number: 3825 Registered: Feb-07 | "i know they're on the cheaper side but would they do the job with a decent quality sound" Depends on how much you guys have to drink. |
New member Username: Techno_kingHampshire, IL United States Post Number: 5 Registered: Apr-10 | see thats why i'm here. i really have no idea where to look. |
Gold Member Username: DmitchellOttawa, Ontario Canada Post Number: 3826 Registered: Feb-07 | If you guys are just using it to crank tunes while partying in the barn the speakers and sub will be fine. |
New member Username: Techno_kingHampshire, IL United States Post Number: 6 Registered: Apr-10 | yea im not talking professional high quality djing or home theater system just a couple of guys chillin |
New member Username: Techno_kingHampshire, IL United States Post Number: 7 Registered: Apr-10 | yea i mean thats all we'd really do i just wanted something that would atleast sound kinda good. |
Gold Member Username: DmitchellOttawa, Ontario Canada Post Number: 3828 Registered: Feb-07 | I'm surprised no one has mention Cerwin Vega. |
Silver Member Username: Vm8444TorontoCanada Post Number: 177 Registered: Aug-05 | yes david's right and I cracked up at his quote.[drink] vega's should sound better then those p.a's http://www.amazon.com/Cerwin-Vega-VE-12-3-Way-Speaker/dp/B000EHUFLI decent wire helps. vm theaudioguy.ca go with vega for your set up |
New member Username: Techno_kingHampshire, IL United States Post Number: 8 Registered: Apr-10 | now with those vegas will i need a separate amp or will the receiver be able to handle the power requirements? |
Platinum Member Username: NuckPost Number: 14933 Registered: Dec-04 | The receiver will be fine. |
Gold Member Username: DmitchellOttawa, Ontario Canada Post Number: 3839 Registered: Feb-07 | As Nuck would say, you could drive them with a potato. |
Platinum Member Username: NuckPost Number: 14934 Registered: Dec-04 | I took that from JV. |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 14823 Registered: May-04 | . And here all this time I've been looking for that potato. Now I know where it disappeared to. |
Platinum Member Username: NuckPost Number: 14936 Registered: Dec-04 | You want fries with that? |
Gold Member Username: DmitchellOttawa, Ontario Canada Post Number: 3841 Registered: Feb-07 | Supersize. |
Platinum Member Username: NuckPost Number: 14938 Registered: Dec-04 | Any CV speaker rated above 95Db should do. They play loud. What JBL speakers play really loud too? |
New member Username: Techno_kingHampshire, IL United States Post Number: 9 Registered: Apr-10 | so is $200 ea. about the normal price of these speakers or is there a vendor where i can find them cheaper. |
Gold Member Username: DmitchellOttawa, Ontario Canada Post Number: 3844 Registered: Feb-07 | Check your local pawn shops maybe? |
Gold Member Username: Mike3Wylie, Tx USA Post Number: 2384 Registered: May-06 | Roselle too far for you? http://chicago.craigslist.org/nwc/ele/1720271386.html Somewhere in Chicago http://chicago.craigslist.org/chc/ele/1717827999.html Sub and speakers and I saved you $50. Cheers! |
Gold Member Username: Mike3Wylie, Tx USA Post Number: 2385 Registered: May-06 | Roselle too far for you? http://chicago.craigslist.org/nwc/ele/1720271386.html Somewhere in Chicago http://chicago.craigslist.org/chc/ele/1717827999.html Sub and speakers and I saved you $50. Cheers! Works better when one uses the link tool. |
