New member Username: PimokyoTurkey Post Number: 1 Registered: Apr-10 | I'm planning to buy NAD c352 soon for a setup which is limited to classical music only and my room is pretty small. So I'm thinking to buy bookshelve speakers. But I'm not sure which speaker to buy. I've heard yamahas are good for classical music. And as you can guess my budget is pretty small. But I can spent a little more, I think. I want to hear all the sounds when listening to music. Do you think this setup will do any good? |
Platinum Member Username: NuckPost Number: 14906 Registered: Dec-04 | If you value accuity in a small space then the Yammy ns might be for you. I find them bright and difficult to work with, but I was in a sound booth. Room treatment and attention are a must! But...if you value accuity, immediacy of strings and a very coherrant treble, then the Yammy NS is worth a look. |
Platinum Member Username: NuckPost Number: 14907 Registered: Dec-04 | To strap them to a NAD amp is a waste of time, IMHO. |
New member Username: PimokyoTurkey Post Number: 2 Registered: Apr-10 | Your post puzzled me. Why do you think is it a waste of time? |
Platinum Member Username: NuckPost Number: 14912 Registered: Dec-04 | I think the speakers are more in a league of a better product to exploit their virtues to advantage. The NAD has a bass bloom, rolled off highs, and does not work at all to the speakers advantage. It does work very well with other speakers, IMO. |
Gold Member Username: DmitchellOttawa, Ontario Canada Post Number: 3809 Registered: Feb-07 | I've owned NAD stuff before and quickly tired of the sound of them. I'm probably not the best source of information since I quickly tire of most most things. Nuck is bang on with the description of NAD, plus add "grainy". |
Platinum Member Username: ArtkAlbany, Oregon USA Post Number: 12512 Registered: Feb-05 | I think that the NAD is the strong piece in this case and deserve a better speaker than the Yamaha. My wife's NAD amp performs very well in her system. I certainly don't hear the rolled off highs. That said, most folks move on from NAD in short order if they are serious about sound. If it's for a small room I'd probably skip the NAD and the Yamaha's and look at something like a used Jolida tube integrated and the Tekton single driver speakers. http://www.audiogon.com/cgi-bin/cls.pl?intatube&1277075106&/Jolida-JD-102B-Amp http://www.tektondesign.com/model45.htm http://www.tektondesign.com/model65.htm |
Silver Member Username: Vm8444TorontoCanada Post Number: 167 Registered: Aug-05 | whats your budget? how about paradigm? studio 20's http://www.audiogon.com/cgi-bin/cls.pl?spkrmoni&1275842377&/Paradigm-Studio-20-v .4-Lower-p or Boston acoustics less expensive immensly http://www.dakmart.com/Audio-Home-Audio-Home-Theater/c4_9_10/p11363/PAIR-BOSTON- ACOUSTICS-CR57-CR57B-SPEAKERS-AUTH-DLR-W-WT/product_info.html?osCsid=2qmjs0qi2bi 9jlj3v4qm6atae5 budget ? theaudioguy.ca |
New member Username: PimokyoTurkey Post Number: 3 Registered: Apr-10 | My budget is around 1000 cash, if I buy speakers several months later maybe it can go to 1500 bucks for amp+speakers total. Only reason I'm considering nad is, its easily available for me and I'm thinking to buy second hand which is around 400 bucks. I was only hearing good things about nad but some people are not very happy with that amp for some reason. The worst thing is, I have no means to try it out before buying and I'm a complete newbie. Thank you mitchell and nuck, for your responses. As for Art, I think your recommendation is very interesting. However I dont know anything about tubes at all, I was thinking that tubes were very expensive, at least 5000 bucks. Sorry for my inexperience. I cant find those brands in my country but I'm looking into it. I'm afraid shipping is gonna cost me. But its ok, I can find a way if I know I want it. Is your setup good for classical music? How about using nad with tektons? Vince, pair of bostons seem cheap to me, however paradigm studio's look very nice. I'm wondering if its gonna be balanced if I used with nad? I'm doing some digging right now. You are all pointing me to somewhere(which is nice), hoping that place is not an "Audiophile Pimokyo" Thank you |
