New member Username: DanreimerPost Number: 1 Registered: Apr-10 | I am planing to run the paradigm AMS 350 for LF/RF, the AMS LCR for the center, the AMS 150R 30's for the rears, and the DSP 3200 for the subwoofer. What are you thoughts on the Integra 50.1 as the AV reciever? Does anyone have any experience with the reciever? Thanks |
Silver Member Username: Vm8444Post Number: 158 Registered: Aug-05 | very nice should sound fine. http://www.paradigm.com/en/pdf/reviews/in_wall/ams350_review_306.pdf they due mention above they like a neutral amplifier so I'm assuming since they are normally mated with B&W should be plenty neutral I gather., and a ft4/cl2 rated inwall spk wire is important.. I like and use these http://www.crutchfield.com/p_70314260/AudioQuest-FLX-14-2-14-Gauge-In-Wall-Speaker-Cable-60-feet.html |
New member Username: DanreimerPost Number: 2 Registered: Apr-10 | Thanks for the reply. I went with Phantom Cables. http://www.infinitecables.com/pop/bk_sp02c14.htm They are made in Mississauga ON and look to be good quality. I looked at the AudioQuest but desided on the Phantoms. I have spray foamed my walls, in your opinion do you think this will increase speaker performance? Thanks |
Silver Member Username: Vm8444Post Number: 161 Registered: Aug-05 | http://www.demilecusa.com/Repository/File/Sound_Barrier_Brochure2.pdf it couldn't hurt I think |
